05.19.2009, 06:37 PM
freezebyte-
I'm all for helping noobs. You've come to the right place if you want brushless advice.
However.... Your logic is flawed. You mentioned in your savage thread, for as much as you spent, you should just be able to take it out of the box and use it.
Well, these are toys, but they are the most highly technical toys I can think of. To think you can just pull it out of the box and use it.... well....the burnt mmm tells the story.
The failure was your fault, quite simply.
If you don't want it to break again stick around and read up. Best of luck.
