Nope, try again- he said 6s lipo when he cooked his MMM right? and stock gearing?
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2.215277777777778
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 20
Total Voltage: 22.2
Motor KV: 2200
Tire Diameter (inches): 6.4
Tire Ballooning (inches): 1
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.2 : 1
Total Ratio: 16.12041 : 1
Tire Circumference (inches): 26.39 inches (670.29 mm)
Total Motor Speed: 48840 RPM
Vehicle Speed: 75.71 mph (121.62 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
I spy an epic fail on the person responsible's part...
