crazyjr
crazyjr's Avatar
05.19.2009, 08:27 PM
The quarks were always twitchy with 6s fresh off the charger, not sure if the caps would help that really- a lower charge voltage (95% say) works wonders aparently.
As for the caps, dont go with the novak module, thats the one that has been blowing up on hvmaxx escs ever since they updated it. The specs you want are:
25v (or 35v), low esr, 105*C, 2700uf (I wouldnt excede about 6000uf if you use several in parallel). A few examples:
one
two
three
I know neil, I was asking because i got the 6s twitchy ones. If the caps help, i might try them, couldn't hurt. I got three quarks, one 80 and two 125, while they may be replaced with mamba's or tekins, i got to make them last for now. but want more out of them and want to experiment with 6s setups. The 80 is on my GT conversion on 5s right now, I want to try 6s setup with the lehner basic XL 1200 kv motor. My G2R is set up with a 5s setup on a 125 w/2.5D neu 1515 (1600kv) I'd like to regear to 6s and 35-40 on a 3095 transmission. The other quark will probably find its way into my 8T with either the 2.5d 1515 or my 2250/10t lehner, if i go 2250 in the truggy, it'll need a big pinion even with 6s lipo's. I'm sure based on the surge ratings, the 125 can handle the 2250, just hope it can take the 6s without burning
The thought has crossed my mind to put the 2250 in the revo on the 3095 transmission, is has the mount holes already
