2 Tekin questions, Both about BEC's
team3six
Just a guy with a box of crayon's
team3six's Avatar
2 Tekin questions, Both about BEC's - 05.20.2009, 12:53 AM
#1. OK, so I have a RC4WD copperhead crawler. I have set it up with 2 servo's. One for the steering and One for the Dig. Talking to Ty from Tekin at the Comp this weekend, I was told that I would need to place an External BEC running the Tekin FX-R w/ 55t brushed motor because the internal BEC only can handle 3A.
So today I purchased a Common Sense BEC. (This one in the link.) http://www.commonsenserc.com/product...roducts_id=323
The instructions http://www.commonsenserc.com/XBEC_Instructions_flat.pdf
basically show use with a lipo and it is rated for 3S and higher or 7 to 28 cells. But the diagram and instructions are for Lipo. Im pretty on top of things when it comes to figuring out electronices. But since it is obviously required I run a BEC. My set up will have an 8 cell saddle pack 1500 NiMH Sub C battery pack. can I still use this BEC or do I need to purchase something else.
#2. the second set up is my Evolution. I removed the Novak system and will be replacing it with the appropriate RX8 system. the issue is that this is a 12 to 14 lb truck, 2WD, and has duel servos for steering in the front. Suicideniel knows this truck pretty well as we have talked about it. Now Niel suggested I should go with a pertiular motor out of the groups. But i am wondering what tekin suggests for this truuck and would this common sense BEC also work in this or will i not have the need for it. It will be running on (2) SMC 2S 5000mAh 25C Lipo's. The servos are (2) hitec HS645MG's. Pics of the truck is below.
It's not just paint! It's an Attitude!
www.team3sixrc.com
