Thread: RX8 Race Report
BUSAFIED
05.20.2009, 08:56 PM
Originally Posted by crazyjr View Post
The neu was probably ok, was it a 1515/1.5d? I was refering to the tekin motor, the 2650 is designed for the buggy not the truggy, its even listed on tekin's site as such. The highest kv motor on the truggy list is the 2200kv, Size wise, the truggy motor would be better at handling the load
As far as the temps, you seem to be ok. I was refering to the tekin motor being a buggy motor, you even said it run a bit warmer over the neu, I think it was because it was a smaller (shorter, as in a 1512) motor than the neu
affirmative...the motor is 1515/1.5D/F. Don't recall where I said the T8 ran warmer than the Neu...in fact, the temp was lower. 123F, if I remember correctly. :)
I have one last test remaining for the T8...if she fails to perform, it's off to the chopping block for her.
