Why not??
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Why not?? - 05.21.2009, 12:28 AM
If you read his first post he does not want to use glued tires any longer. I feel the same way. I like my Axial beadlocks with 40 series tires. Like I stated if you build your vehicle to stand up to the type of punishment that you throw at it, then you will have the kind of truck you are looking for. You can go two ways with this. Purchase and install the wheels you want and repair whatever breaks in your drivetrain, or look closely at your setup and start getting the upgrades that you know you will need and rebuild your truck once you have everything in hand.
SUPERMAXX YOUR LIFE.
