JThiessen
JThiessen's Avatar
05.21.2009, 08:42 AM
Thiessen, you said 1/2 inch, I really am confused here now....
I tried them in an E-Revo that was sitting in the hobby shop. So it likely had the foam on the inside. Remove the foam and you get to the 1mm difference. Then add on your wrapping material - likely another mm or two.
I think a pair of velcro straps in lieu of the door would work just fine - might be difficult to find a spot to attach the straps though.
