zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.21.2009, 02:57 PM
crazyjr, if you are referring to the glitching issue, I mean 6s lipo packs with the Quark... I remember ppl having problems with it, but I think it's only when you use lipo mode on the Quark, NiMH mode is not prone to this issue.
timaneli, so you fit 2 cells wide pack in the boxes then. Well makes sense if you look at the 51mm measurement of the boxes, and 52mm of a 2 cell wide M1 pack. What kind of gap is in the bottom of the hatch/cover/door/lid (whatever you want to call it) Can it be filled in with some kind of sticky foam?
