05.22.2009, 01:29 AM
pull your front driveshaft and run it. if your worried about it unloading to the front just wire a shaft(allen wrench, anything) through the front cup to hold it stationary. do a couple high grip passes and see if the tickings gone. don't run much its hard on the center diff, but fine for a couple passes. that'll get you 50% diagnosed......
