RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.22.2009, 11:48 AM
Joselito(George) - your tray arrived here today. The tray is an old one(likely a year old or more, as it is the old style tray). I also suspect it was procured 2nd hand by you, as I can't find a purchase record from you for a tray. I assume you have the spacer still attached to the chassis? Our newer trays have the spacer built in - would you like the newer style or the older flat bottom style for a replacement? The inside was also modified slightly on one wall - do you need some extra room on the inside to prevent it from bowing out?
Ian(BL_RVO) - haven't seen your tray yet.
