05.22.2009, 01:49 PM
You guys make really good points.
I was thinking that runtime would be better if I had (3) 2s packs, but that doesn't make sense because it's all still the same amount of cells. The overall runtime should be the same if it's geared for the same speed. Actually it should be better with 3s geared lower because it's more efficient.
One reason I considered 2s is for the sake of the poor Sidewinder. If I go 3s, won't I have to install a CCBEC?
If I go with 3s, then I could use those packs in the Losi 2.2 crawler when it finally comes out.
Thanks again for your help.
