12.25.2005, 02:02 PM
2 things i should let you know. dont use wabash, hacked or not as they will make your truck as narrow as the original t-maxx (1 inch narrower) and 2 just look at what happend to promod when he used them on his truck. the thread is called "lehner owns me a tire!". the reason that they are so light and the reason that that happened is because they are made of thinner rubber than most which will make them balloon really bad. the responses on wabash rims (that arent and dont HAVE to be hacked) weighs just 7 ounces a piece, which is 3 ounces lighter than the stock revo rims and tires. which if im not mistaken is what you run.
