Thread: goda know
stampy
stampy's Avatar
12.25.2005, 07:47 PM
"Brian,
Charging Through STAY BALANCE MODULE™ using DURALITE PLUSTM Brand Charger.
The module, when used in conjunction with the DURALITE PLUSTM Charger , also acts as a voltage limiting devise.
First plug in the MODULE & balance the pack before connecting the charger. Then plug the Module into the DURALITE PLUSTM Charger by connecting the yellow charging lead connections. Then begin your charging cycle. Although the balancer was designed to be used in conjunction with the Duralite Plus chargers it has been used with other chargers connected thru the yellow lead. You will need to construct a female adapter for your charger to plug into the balancer yellow lead. If you choose to do this, make sure that your charger is set at no more than 400 mah charge rate or .4 of 1 C."
i emailed duralite about hooking up there balancer to a diff charger
