05.25.2009, 03:04 PM
If you plan to run lst diffs you will need to do both front and rear as they are different ratios to the revo diffs. Not much work, but you will have to do some grinding of the stock bulkheads with the dremel, and figure out what center drives and driveshafts you plan to use. Mistercrash has a nice writeup on all of the cool revo mods...
