Thank you... so I run the losi 2.0 E w 45(plastic)/15 gearing .. with your 46t what pinion should I use to be close to that gearing. Also can I use the Losi lightend outdrives with this Dif. ( still have to shim 1mm for gear clearence?)
Have the Losi 2.0 E with Tekin 2050 and zippy 4cell.
