FS: Sand Rail - Parting out
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
FS: Sand Rail - Parting out - 05.26.2009, 02:30 PM
Well I can't seem to sell this thing as a whole, so I am going to try parting it out.
I took a slash, chopped it up and built a sand rail chassis for it. First things first, the chassis is not perfect. If you hit something at speed you will bend it, it's only brakeline. However it bends back very easily, as brakeline is meant to do. It is not "symmetrical", but does look good when you stand back. Now that we have the bad over with, onto the good.
vxl brushless system-about 15 runs
RPM goodies:
front c-hubs NIP
bearing carriers all the way around
Front a-arms
Other goodies:
a pair of proline sand paws mounted on hpi wheels
Stock front wheels and tires
Geolanders mounted on hpi wheels
Full set of proline switch tires, 2 on hpi wheels and 2 that are not mounted. the two that aren't mounted have been glued, so the beads are a little ugly but should be able to be cleaned up, they are not torn. The set on wheels needs to be balanced.
Also for the truck, I have some traxxas big bores for the front, they are on their way in the mail. should be here pretty soon.
I also have a ton of misc. stuff
If you would like more pictures, let me know.
PM for prices please.
