05.26.2009, 06:12 PM
And what about the motor? That would be just as important IMO, and it's gonna be tough to keep the water from messing up/rusting the bearings and shaft (although they could coat the shaft I suppose). There is potentially a lot of fine dirt suspended in ground water. Personally, if you want to run through water, get a boat, or stick with a cheaper brushed setup.
