SERVO SAVER problem
robknasel
SERVO SAVER problem - 05.26.2009, 09:01 PM
Hello,
Wanted to give you some insight to what the servo problem is. The servo saver spring that it included with the 8ight 2.0 is too large. The coils of the spring are almost touching each other already and this does not allow the spring to compress well. The fix is to simply buy the fiorini spring that A Main carrys. This is a upgrade part and you may need to look for it in the 1.0 section. It will work on the the 2.0. Smaller spring gauge and the coils are further apart, allowing the spring to actually work.
Rob Knasel
robknasel@me.com
