superek4
superek4's Avatar
05.27.2009, 08:52 AM
Just enter the diff ring and pinion gear ratio into the calculator.
regarding the bearing damage - was it a new bearing when you installed it, or was it a carry over from prior to installing the Slipperential? I doubt the spacers caused the failure, Alan - more likely wear and dirt over time or perhaps improper installation. The actual load on the CD bearings is a very small fraction of the load the 8x16 bearings are capable of and spacing them out the amount needed won't cause damage.
Thx Mike I will check n put 2 new bearings to test again, I m very happy with d slip diff my CRT no longer wheelies n steering n throttle is smooth.
Is there anyway I can remove d screw of the diff ring? I rounded it:(
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
