JThiessen
JThiessen's Avatar
05.27.2009, 10:30 PM
2 feet of L angled aluminum later....
Battery tray anyone?
Maybe put something on the bottom to protect it?
Eh - been there done that...
Originally Posted by TexasSP View Post
You can get C-Channel 6061 which would do the trick. Just pick the closest size you need, machine out the excess then add to end pieces the use screws to hold them. Weight could be just as light as delrin and some other plastics.
I bought some C-Channel aluminum about 2 years ago at my former employer which we used on machine we were prototyping at the time. It saved a lot of waste both in material and time.
Not a bad idea. I'm pursueing this for the look of the machined AL. I could probably chuck up a piece of thicker channel that I have at work, and just do a fly cut on it to give it the machined look. Unfortunately we have quite a bit of slop in one of the ways, and its the long direction - dont know for sure if I have 6+ inches of travel in the good direction.
