Unsullied_Spy
Unsullied_Spy's Avatar
05.28.2009, 12:09 AM
Micro T/B is smaller than the DT, I'll get you approximate measurements on my DT's battery compartment.
EDIT: 35mm long, 38-39mm wide, and 12mm deep. There are 2 protruding nuts in the front corners of the battery tray that will interfere with the fitment though, with my Losi lipo in I put the foam spacer at that part otherwise it won't fit properly.
