05.28.2009, 05:01 PM
Originally Posted by Rebelgium View Post
True, but the Aluminums will only break under much heavier impact than the stockers can handle. And once it's been bent it won't last very long anymore.
But true, IF they do break, they're broken... :)
You can bend steel back with little to no impact on how it will withstand future use. One of the many benefits of steel (I personally think that steel is a much better material for most stuff these days).
I would and do run the steel pushrods, mainly cause I have sheared off the threaded portions of the al tubez more times that I would like to think. I have even threaded the tube to use a m4 threaded rod, that cured the shearing issue, at least on that end, the other end sheared off the next time I ran.
