05.29.2009, 12:45 AM
Originally Posted by traxxasbasher13 View Post
Yea I am going to need to figure something out. Maybe I will take a CD mount and mod it to fit my motor then hook up some brakes.
If you can find some sort of cd cups that have the brake flats and have 8mm bore you would be good to go. Something like Mikes CD mount but with the mount holes arranged around the bearing holes would be good. One at each end of the motor to support the shaft will help the motors bearings, especially on the spinning can side.
