05.29.2009, 10:10 PM
Nah something definitely fried because of the messy solder job. It worked fine the first time I incorrectly (I got the sequence messed up. I think I hit full throttle when I was supposed to be at neutral, it ended up running slowly while in neutral) calibrated it. The motor beeped the proper number of times with the LED flashing as I went through the steps. I turned it off and back on and went through the calibration again and the LED flashed properly, but there was no beeping from the motor, and the motor did not run afterwards.
Anyways, I already got an RMA number. Ugh man I have the worst luck.
