Chargeing with hyperion duo
dirtdiver
Chargeing with hyperion duo - 05.30.2009, 10:12 AM
Just wanted to know if you can charge two difference battery's of different
volts and mah together on the hyperion duo? I know you can charge two
battery"s of the same volts and mah together,but it doesent say anything
about chargeing two battery of difference volts and mah in the manual.
Let"s say i have a battery,true rc 14.8 volt 4000mah,and a flightpower
14.8 volt 5350 mah battery,can they be charged together in solo mode?
or do i need to charge them seperetley.
