05.31.2009, 02:20 PM
You can also find a pinion puller, or rig up your own with a slightly modded battery terminal puller available at the local auto parts store... Or just cut the pinion in half parallel to the shaft, stick a flat blade screwdriver into the slot and it will spread it enough to get it off.
