Originally Posted by aqwut
Been running 12S in my vehicles for quite a while now.. 12S Car capable ESCs are just expensive... you have the shulze, kontronik, MGM, and some others... I've been keeping mechanical brakes and just using Cheap $100 ESCs.. seems to work great for me... but This year, I've been cutting everything down to just 6-8S... 12S is just too insane to run... unless you're setting some speed records like JzeMaxx and some other crazy guys.... The Cheap hobbywing escs are pretty darn smooth for the $100 price tag...
I will be running 2 of the turnigy force hv escs in the baja 5b conversion... Hope they do well. I plan to use mech brakes, and not have reverse... I like reverse though. If someone brings out some potent 12s car escs I will swap to them for reverse. Although mech brakes on heavy vehicles is a good idea. I can mix mech and elc brakes with the m11 so that is cool too. I may even be able to switch off the mech brakes and use reverse, will have to see if I can assign that feature to the radio...
