Originally Posted by _paralyzed_
what antenna mod? my micro antenna is toast
Look at how I attached my antenna. It's made out of a strand of cat5 cable. You can solder it or just coil it around the screw that's supposed to be there and tighten it down.
I used a full deans plug because it was easiest and I don't need to get a charge adapter and go though all that crap...
Hobbycity lipos are all I will ever get for my micro. I got a 610mah one and it's pretty heavy and it's what I think contributes to my motor overheating. There is a 460mah lipo that fits a little better. I had to take all the plastic off the sides to get mine to fit. Here's a pic of a 410mah in a micro dt.
http://www.rcuniverse.com/forum/fb.asp?m=8551392
BTW mine is a Desert truck
