Originally Posted by ZippyBasher
Yeah man how about the dubra ball ends? I snap a rear toe-in ball end just about every other run and pretty am tired of it. Let me know the scoop if they will be much better.
I got the 3mm monster ball links after trying to figure out which size I needed I actually emailed dubro and they couldn't tell me much they said to take my rod to a capable hardware store to have them measure the size and the threads per something. I just cut them to stock length with a drimmel and drill the hole out alittle bit so the threads on my rod would grab enough to start. I've done bad things to this truck and they just keep coming back for more. I have a 3906 with 3905 type suspension and I used the 2 supplied little brass colored spacers on the outside at the knuckle. Thats it.
Here are all the Monster links at Tower:
CLICK
