RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.03.2009, 09:43 AM
Originally Posted by Freezebyte View Post
So wait, you've tested ALL the batteries you sell on your site to be gaurenteed to power a Flux without killing it?
Well lets not put words in my mouth here - there are far too many variables - if you used a 4s 2600mah pack in the Flux geared for 50mph, I would expect problems. The packs we sell are top quality, but the customer still has the responsibility to select the proper "tools for the job". A properly selected pack and proper gearing with any of the packs we sell will minimize the possibility of failure - specifically battery related failure. Nothing has 100% reliability, and there are many factors that can cause failure - the key is to minimize the potential causes in order to maximize the reliability - this same thought can be applied to anything you do and is the real message here.
Zippy or Flightmaxx in and of themselves are not a "cause of failure" most likely - its the combination of a lower end battery and unrealistic expectations leading to unrealistic operating conditions.
If you run a Ferrri on low grade gasoline, you have nobody to blame but yourself when it develops a ping and runs like crap. If you can't afford "premium", then get a Ford. The same message applies here - if you run lower grade batteries, you must lower your performance expectations and make the appropriate gearing and setup considerations to ensure longevity. :)
