SpeedAssault
SpeedAssault's Avatar
06.04.2009, 12:33 AM
Hey guys what do you think,
time to place the motor and tranny and weld up the shafts so would you say mount all the way forward or partially ?
Also
I'm thinking I should mount motor all the way up front and slightly to one side and use the 6s lipo on opposite side to counter the weight, On the other hand mount motor in center 1:5" above chassis
I like the look of centered but offset gets it lowest CG, what do you guys think ?
Got the motor/tranny mounts finished but having second thoughts
Built it so the motor is just slightly off center but close to the bottom.
ID:	7201   Click image for larger version
ID:	7202   Click image for larger version
