06.04.2009, 03:06 AM
What I've done previously is tape over all openings on the motor, then clamp the shaft level in a vice so only the area of the shaft to be removed sit proud of the vice jaws than grind down to the jaws, quick tidy up with emery paper, remove tape...easy peasy - good to go!!
