brushlessboy16
brushlessboy16's Avatar
06.04.2009, 07:51 PM
Which one of you is the girl?
Anyway, I've been wanting to do something like this for a while. I primarily like driving games, so I figure it would take less room than my Logitech MOMO and help he improve my pistol grip controller driving skill. But, if I was going to do it, I'd want to change the pots to rotary encoders - pots wear out too fast. Speaking of which (and slightly off topic), when are the higher end radios gonna start coming out with encoder-based controls instead of crappy pots?
the same time they come with built in usb interfaces...
UPDATE got the original pots from the joystick into the Transmitter- way better resolution.. i only wired them wrong about 12 times.
Here it is.
New Pots
Old pot and trigger mechanism housing
New pot installed on housing
Stock steering wheel assembly
New pot fitted and glued.
Minor modding was needed to adapt the plastic components to the new Pots- all things that can be done with a sharp exacto and a couple dril bits. Hotglue really helped out providing a good adhesion but removable if necessary
