06.05.2009, 12:51 AM
The wiring is not permanent, just threw it in there to tr out my setup. I had to laugh when I saw your wires wrapped around the motor leads! Only with spectrum would that work!
What do the diffs have in them stock? Grease? feels like it. I need to move the MM over and back a bit, and reroute the signal wires. I will leave the rx on the servo, as I like the antenna routing there. Plus I can make a wire clamp for the signal wire next to the rx, using those 2 bolt holes.
