Aluminum slipper pad update
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
Aluminum slipper pad update - 06.05.2009, 12:45 PM
I forgot I wanted to give an update on the aluminum slipper pad with the Belleville springs. It works awsome! The Belleville springs make the thing very adjustable and it keeps the setting much better than the stock spring. That aluminum slipper pad gives very good, consistent and controlled ''slippage''. It eliminates wheelies running 4S. It still will get the nose up to the point of having the rear wing scrape the surface you're running on, running on 5 and 6S. But the truck will not flip. And finally, that aluminum slipper pad lasts a long long time, I'm still running the very first one I made.
No brain, no headaches.
