My E-Jato is glitchy. Why?
jpoprock
"Don't act like you're not impressed."
jpoprock's Avatar
My E-Jato is glitchy. Why? - 06.05.2009, 02:27 PM
Hey guys... I have an E-Jato that I purchased 2nd hand. I changed some things around on the configuration, but I think more work needs to be done. For NOW, I put the ESC in the rear battery compartment, but I think I'm going to relocate it to the front of the veh. The reason it's back there, is because I wanted to get it as far away as possible from my other electronics because the truck was very glitchy. Once I moved it, it only became "kinda" glitchy. Like, it won't respond to my radio commands all the time. It does so when it wants to. It'll get kind far away from me after a speed run, and I won't be able to steer it or engage the throttle. So I'll start walking closer to it and finally it'll kick in.
My receiver is in the front of the car, next to the throttle servo. My Lipo is laid across the center of the chassis in front of the CC 5700kv motor, and my Sidewinder ESC is in the battery box, uncovered, but secured with heavy duty two way tape, along with my on/off switch. The wires for everything passes under my motor, over the tranny, and into the battery box.
Do you think I really need to go thru "twisting" all the cables? I'm using a Spectrum DX3.0 radio and an SR3000 receiver. The Throttle servo is a Hitech I think, and the steering is as well. If I could get this glitching problem dialed in, i'd be a happy camper because this thing is wicked fast! I can post pix if you need them. I didn't want to post pix just yet, because it's a work in progress, and I didn't want people ripping my set up, because it's not at all set in stone!
Edit: I also wanted to say that my Jato uses the 2spd tranny. But I'm hip to converting to single speed if the truck will go as fast or faster. That way I can ditch the brakes and throttle servo, etc. That would help a bunch I think. Like I said, I bought this 2nd hand, and really don't know much about the E-Jato conversion process. I have a Nitro Jato, but was hoping this would take the place of the Nitro, since I'm growing to HATE messing with Nitro these days.
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
