scarletboa
scarletboa's Avatar
06.05.2009, 07:02 PM
Originally Posted by BADBOY2 View Post
thanks ,btw 15c discharge is not bad??i was lookin at that charger is it good?how long will it take for that charger to charge the 2s 5000mah ?and u said theyre actually 20c?would that be a problem in charging them?and can u change the connectors to deans?just wanna make sure does that charger have balancer too?thanks!
i was looking around in the hobbyking forums and one of the admins stated that that the packs are mislabled and are indeed 20c constant, 30c burst packs. they will be more than enough for your feigao.
the charger has a very good balancer in it and you do not need an external one.
yes, you can cut off the plug and solder some deans plugs on them. that's what i did with my zippy flightmax packs.
it will take about an hour for a full charge on the 2s and about 70-80 mins for a full charge on the 3s pack.
you can either get 2 of the 2s packs, or you can get more power and speed by getting 1 2s pack and 1 3s pack.
