sikeston34m
sikeston34m's Avatar
06.06.2009, 12:42 AM
I've got a bec, and THANKS for the info about the soldering. Man that had me paranoid.... Next time I take the gear cover off I'll let you know. Should be soon cause I have to put heatsink compound on...
Where's the best place to get a fan for my mamba max? orrrr can I remove the heatsink and put a copper one on. That's a great idea...
I'll shoot griffin a pm.
The fan that fits the MM the best is the 25mm fan. The mount holes in these line up perfectly with the fins in the heat sink. The 25mm fan that Novak sells puts out more air than comparable versions.
Seems like I've seen pictures where a 30mm fan was used also. It has to be turned diagnally though so I opted for the 25mm square fit. There is risk of damaging fets if you try to remove the heat sink. I wouldn't risk it.
One way to drop temps on the MM with 4S is to add a low esr cap to the power leads. 1000uf or more total.
Are all of your cvd's bent? I just installed mine, and already have one that's bent. If you have a few that are good and straight, I might be interested. I ran into something hard and bent one.
