zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.06.2009, 01:08 AM
Thanks guys...
Hi ZPB,
I have lots of questions here.
I'm working on a RC Lawnmower.
How many inch cut is yours?
You said you were looking for another motor? Can you push that motor by bumping up the voltage some?
What's the general size and what size shaft? RPM range on 24 volts?
I know you don't wanna spin the blade too fast or it could have a come-a-part.
The cut width IIRC is 18 inches? I could be wrong.
I was thinking the voltage boost from the 8s6p pack would just keep the voltage high enough that it would give it that extra power needed. Although, a 10s5p pack might work good too, because I just went and tried a 10s1p pack and i sounded like it had potential if it had enough capacity and voltage holding
I don't know on the shaft size or the RPM/v, couldn't tell you. I think the motor shaft must have some kind of adapter on it to make it the right size for standard mower blades.
ID:	7214   Click image for larger version
ID:	7215   Click image for larger version
