kalbien
06.06.2009, 04:24 AM
You may find that to be a tad too high and runtime may be reduced (probably only by about a minute though). Like I said before, set it to whatever, run your vehicle until the LVC kicks in, disconnect the batteries and let them sit for about 10-15 minutes disconnected. After that, see what the voltage is. If it's over 3.6v, you could bring the LVC down a tad. If the voltage is lower than 3.5v, bring the LVC even higher.
this one sounds really ok, I will do it like that , thanks a lot...
batteries I am getting are http://www.hyperion-eu.com/products/...-LG335-3300-5S with geared to 55-60km/h plenty of capacity for 7mins mains and charge/discharge rates are really nice.
Thanks for help , hopefully I won't fry those :)
