Kcaz25
Kcaz25's Avatar
06.07.2009, 12:09 AM
Yep, but:
"Max relay current: 1A @ 24VDC, 0.5A @ 125VAC (60W lightbulb)"
You could power several dozen LEDS with it, seeing as your typical 5mm 6/12v item only draws a few mah- that PicoSwitch would be ideal for what you need, you'd just have to wire the LEDS up, and then find a seperate power source for them (the radio/ rx turns the circuit on and off, but it doesnt provide the power for the LEDs)- something like a little 9v battery would be fine.
I'm not sure excatly what you mean Neil. Why don't you pick one out for me.
Signs of a good weekend! Ignor the Crock Pot! Long boring story!
