06.07.2009, 09:39 PM
I've had good luck with the HXT 12kg servo. It has enough torque to turn my e-revo wheels on cement and it has metal gears, a lot of torque,,, It only costs $8. Just make sure to use washers and be careful with the mounts, because I've broke a couple. If you have a solid mounting point like most vehicles do and you use washers you'll be fine.
