06.07.2009, 11:37 PM
The KB has plenty of power, but has a 30mm bolt pattern and 6mm shaft. So you are stuck with making a mount and either turning the shaft to 5mm or using plastic spurs and the small selection non hardened pinions.
Go with the MMM/2200 combo. Best deal you will get.
