06.08.2009, 12:07 AM
Originally Posted by junkman View Post
same here, getting the dude's mount, and hub, havn't decide to go with the collet adapter, or buy a few new pinions.
If you can do gearing with 25t pinions or less go with the rcm hardened pinions. If you have to run larger than 25t pinions, say you plan to run a low rpm motor or want alot of speed, go with the tdr colleted adapter and Mike's 2 speed 2nd gear screw on pinion, he has them up to 30t.
I have the tdr adapter modded to fit one of my 8mm shaft 1527 motors. Nicely made, just like the rest of his stuff.
