Ryu James
Ryu James's Avatar
06.08.2009, 03:19 PM
Originally Posted by exawatt View Post
If you run it with the setup above it will not be drivable. All it will be good for is destroying tires and screwing around in a walmart parking lot when its empty(hahah).
I will have a single speed diff this weekend and will be taking it to the track to see if it helps.
so i think running a 2 speed would be cool but it sounds like it is total overkill. what is a good, drivable, fast setup? i am thinking of just going single speed with the Neu 1512 2050kv on 5s 2600mah. would this be a decent setup? also, what kind of diff can i use for the center diff? do i need to run just a spur gear or would it be ok to acutually run a differential?
Jammin SCRT10 Neu 1512 1y
