Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.09.2009, 02:01 AM
PVC and abs are different materials as the products used to bond them. Pvc/abs cement chemically bonds the plastics and makes a PERMANENT bond between two pieces of plastic. It's impossible to dissasemble a spud gun,(or battery tray) because the cement makes it one single piece of plastic. PVC cement probably won't work with abs.
Good point is PVC usually recommends a primer before cement, hence those double packs of primer/cement. Primer makes the plastic ready to accept the cement. Abs doesn't use a primer that I can fnd.
