glassdoctor
TEAM FUSION
glassdoctor's Avatar
06.09.2009, 10:15 AM
When you balance charge, they won't be out of balance unless something is really wrong with one of the cells. If one cell has less capacity than the others, it's possible to over discharge that cell (or just have it at a lower voltage than the rest) when you run the pack to LVC. It would be out of balance at that point... but will be "fixed" on the next charge. No damage would occur as long as no cells go below 3v.
If you are curious, you can check the cells voltage when the pack is first hooked up to charge. If the charger doesn't display the individual cell voltage, you can use dvm.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
