Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.09.2009, 01:40 PM
That would work if I was testing 120v batteries. That heater's element is around 10ohms. I would need at least 3s just to get 1A out of it. Thanks for the suggestion though!
I was thinking it would be possible to make a "reverse power supply" fairly easily. Convert the voltage from the battery to 110v for the space heater. The space heater may even have a power supply to step down the voltage a little?
Or, instead of a resistor, you could hook itup to a bigger motor driving a fan or something....
