Originally Posted by lincpimp
A decent cell meter that plugs into the balance port is a good investment to check the individual cells before a charge and after you have stored the pack. Not sure if your hyperion has a balancer readout screen, but I am pretty sure it does. During the charge I think you press the mode button to get to the balancer screen and then you can use the up and down keys to get to the individual cell readings.
The Hyperion 610i does read off cell voltages in main options you'll need to press mode till it goes to balancer then it will give you the readings, its most likely that if a hyperion charger has the balance tap option built in it will offer all these features I may be wong though.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
