12.31.2005, 05:16 PM
If you run the 6mm cvds and metal idler gears with the titanium center shafts. The only part i would worry about would be the diffs. If you running the titans I wouldn't worry about them but so much. The pic for the center shafts is used in all of the choices. The bottom one is the one I was talking about. You can email mike and he can hook you up with all the stuff you need. You may want to look at running the flm hybird for the 1/8 buggy diffs if you bash alot. I run the 6 spyder gears with no problems yet.
